Banshee Chain Adjustment?!?
Old Apr 15, 2000 | 03:10 AM
CeetBanshee's Avatar
My chain is loose and it grabs and makes noises I know aren't correct. I don't have a manual so can someone tell me how to tighten my chain please?? The sooner the better, I want to ride tomorrow!
Old Apr 15, 2000 | 03:50 AM
DunePilot858's Avatar
There are two bolts that hold the axle carrier to the swingarm that need to be loosened. Next you have to loosen the lock nuts on the adjuster bolts... the two that face the rear... next you turn them until the proper amount of slack is in the chain and tighen the lock nuts down. Tighten the bolts that hold the axle carrier. I have only adjusted my chain once. It was pretty loose but since then it hasn't stretched. I need a new chain and sprocket set soon though.
Old Apr 15, 2000 | 01:30 PM
hot_shoe_cv's Avatar
I'd strongly suggest that you invest in a Clymer's manual. I believe you can order one here at ATV Connection's home page.
Just a couple of things to add to DunePilot858's explanation..be sure to have the reference marks on each adjuster in the same position to insure alignment of the chain with each sprocket. Also do not tighten the chain beyond 1 1/4 to 1/1/2" deflection, measured from a midpoint between the two sprockets . Too tight results in abnormal wear on chain, sprockets, & transmission.
Old Apr 16, 2000 | 01:42 PM
I tried it, I didn't get it tightened. I already ordered a manual, but I won't have it until wednesday. I guess I'll just let the Banshee sit until then.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
