'00 500 cooling fan problem
Old Feb 13, 2003 | 12:46 PM
Tick's Avatar
Default '00 500 cooling fan problem
I was riding last weekend when the cooling fan quit on me. Now it won't come on at all. Has anyone had problems with the diodes or fan motors?
Old Feb 13, 2003 | 06:13 PM
troutmaster28538's Avatar
Had a 98 arctic cat 454 i had to replace the fan after 2 yrs it wouldnt turn at all.
Old Feb 13, 2003 | 10:21 PM
Win3855's Avatar
I wish it was warm enough to have mine come on. -8 degrees here in Maine now. BRRRR
Old Feb 13, 2003 | 10:59 PM
glad i'm not in maine, i'm getting cold just thinking about it lol
Old Feb 13, 2003 | 11:02 PM
46 degree's here in north carolina
Old Feb 14, 2003 | 02:09 AM
swampdonkeykiller's Avatar
Try turning the fan with a pen or something to see if your bushing hasn't seized up. If it turns freely, unplug your fan and check for continuity with an ohmmeter. If it has a really high resistance or has no continuity then your fan is NFG. If that checks out then eitheir your sensor, or your wiring including relays and fuses may be the problem.
Old Feb 14, 2003 | 05:17 AM
kindsambo's Avatar
If you do have to replace your fan, get one from from the junk yard off a small car. I replaced the fan on my kodiak with a fan from a 91 Chev Sprint. It bolted on with VERY little modifications and it works perfectly. Total cost of my fan replacement....$5!!! The dealer wanted $369 for a new fan for the kodiak...at that price he can keep it.
Make sure when you wash your Cat to get all the mud from around the fan so the blades can spin freely. I ruined my fan because the mud dried around the blade so it couldn't spin which ended up burning out the motor. I was also told that the fans can be taken apart and new brushes put in. I didn't try rebuilding mine yet but I will in the spring. Good luck.
Old Feb 14, 2003 | 02:10 PM
Tick's Avatar
Thanks for the info.
Old Feb 22, 2003 | 07:40 AM
ricerocket's Avatar
check the fuse in 2000 the fan funs constantly no temp sensor like the old ones. i blew fuses constantly on my 2000 400.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
marshel
Jul 25, 2015 07:17 PM
clsharky
Jul 13, 2015 02:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
