96 BEARCAT 454 CDI PROBS?
Old Feb 21, 2003 | 01:18 PM
NATE5677's Avatar
Default 96 BEARCAT 454 CDI PROBS?
I AM LOSING VOLTAGE AT MY INGITION COIL INTERMITTENLY, AND RIGHT NOW ALL THE FINGERS ARE POINTING TO THE CDI UNIT, BUT I NOTICED THAT THE HEADLIGHTS FLICKER TOO, WHEN THE VOLTAGE DROPS. NO SHORTS OR BAD CONNECTIONS, ANY HELP WOULD BE MUCH APPRICIATED. MAYBE THE VOLTAGE REGULATOR OR STATOR??????????????[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img] THE MACHINE IDLES SOMEWHAT AND ALWAYS STARTS, BUT WILL ONLY RUN GOOD FOR A COUPLE OF MINUTES BEFORE IT STARTS POPING AND MISSING, THATS WHEN I MEASURED THE VOLTAGE DROP AT THE COIL. SOMEWHERE ITS DROPPING DOWN TO 40 OR 50 mV WHEN AT IDLE IT SHOULD BE 115mV.
Old Feb 22, 2003 | 12:28 PM
voodoo's Avatar
Not sure what it could be... My machine did somewhat of the same thing. I had corroded connections at various points in the harness. Go over the harness with a fine tooth comb and you may find something. Unplug and inspect all connections. I had bad points at the connection up near the CDI. I hope its not your CDI, they are expensive.
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
southbayman
Jul 24, 2015 09:30 AM
gregsims
Apr 1, 2001 09:12 PM
Fijit
Where to Ride
Feb 6, 2000 01:01 PM
