Pros & cons?
Old Feb 17, 2003 | 05:44 AM
Y2JRaptor660R's Avatar
Default Pros & cons?
What are the pros and cons of having +1 forward a-arms?
Old Feb 17, 2003 | 05:48 AM
DaBeechMan's Avatar
your wheels are +1 in the front which gives you better stability. Cons? none that i can think of
Old Feb 17, 2003 | 12:02 PM
AlkyBurninX's Avatar
1" forward means you sit closer to the axle and the weight center is more reward for traction. You can shorten your swingarm 1" and keep the same wheel base while bringing the axle under you. Quicker, more precise turning.
My experience in on my banshee with +2, +1 a-arms and a -2 swingarm set up for flat track racing.
For general riding though, more wheel base is not always the best and a shorter swingarm really isn't good. If you are planning on stretching it out with longer swingarm and wider a-arms, go ahead with the plus 1 forward. I wouldn't go with plus 1 forward a-arms only though.
Old Feb 17, 2003 | 12:06 PM
ltz400racer's Avatar
pros..you can corner like your on rails..cons..its a tight fit in the woods..if you dont ride in the woods alot dont worry about it
bmxatv10
Oct 14, 2022 06:23 PM
Customer Service #1
May 15, 2020 08:46 AM
Sep 15, 2015 02:42 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
