500 scrambler 4x4 transmission ?
Old Feb 17, 2003 | 12:15 PM
troyr's Avatar
Default 500 scrambler 4x4 transmission ?
I need to rebuild my tranny. I need to know exactly what book I need that show how to put it back together and where to get it.
Also I read somewhere the I had to take the primary clutch off to do this. Should I upgrade anything while I'm in there?
Old Feb 17, 2003 | 07:00 PM
ftwflh's Avatar
I have both a factory and a Clymer manual the factory goes into better detail but the Clymer has better pictures.It is a rathe simple job harder to get the tranny out and back in than to rebuild it.While it is out I would check the bushings and buttons in the primary and change the buttons in the secondary.If you like the way it pulls and run leave the stock springs in the clutches but if you want more out of it get you a clutch kit.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
