Smokin Blaster
Old Apr 16, 2000 | 01:42 PM
250xrider's Avatar
I have been mixing my blaster at 32:1, it has been smoking a lot, and a little oil is coming out of the silencer. Does anyone know what i should mix at? Thanks
Old Apr 16, 2000 | 04:58 PM
99blueblaster's Avatar
32:1 is fine
Old Apr 16, 2000 | 05:04 PM
250xrider's Avatar
What do you think is making it smoke?
Old Apr 16, 2000 | 06:37 PM
It is a 2 stroke. Smoke is good. That means that it is getting oil! Mine will also ooze some from the exhaust at the motor. If your plugs are not fouling than you should be fine. I run mine a little on the rich side because I ride all trails and sometimes I dont get alot of air moving around the motor so I need the extra fuel to help cool it.
Old Apr 20, 2000 | 02:29 AM
warrior007_2's Avatar
sounds to me like the jetting (air/fuel) is rich and not the mixture (fuel/oil), check the plug, warm up the quad and ride 100yds in 3rd gear at half throttle, then pull the plug and check to see if it is black
Old Apr 20, 2000 | 12:22 PM
2000_blasterboy1's Avatar
Ok, when you do a plug test, how in the @#$% do you not burn your hand on the head?? Please, i'm tired of burns!!!!
Old Apr 20, 2000 | 10:54 PM
99fasterblasters's Avatar
Gloves!
Old Apr 21, 2000 | 01:17 AM
yam's Avatar
yam
VERY CAREFULLY
Old Apr 21, 2000 | 10:25 AM
YJW's Avatar
YJW
There is one other possibility here. The pto end seal may be leaking allowing the engine to consume trany oil. You would notice the oil continuosly going down as well as a different exhaust smell. Similar to an oil burning car smell.
Old Apr 21, 2000 | 01:40 PM
250xrider's Avatar
Hey, you guys thanks a lot for the replies. I think the owner before me put in bigger jets, and i was runnning the stock airbox. I put some holes in it today and it runs a lot better. Thanks for all your help
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
