Reverse question ....
Old Feb 17, 2003 | 04:26 PM
wvBowHunter's Avatar
Default Reverse question ....
I apologize if this has been asked before but, I've had a few problems while in reverse .... While in reverse, it feels like I'm running outta gas, or like the ignition has been retarded. It happens 35% of the time .... Now, I read in the owners manual that there's a speed limiter while in reverse, but I'm crawling .... Also, is it normal to have to adjust the idle speed on a new bike? It's got 19 Hours on it and I just completed the initial oil change....
Old Feb 17, 2003 | 04:30 PM
Scotts88's Avatar
My brothers scram 500 seemed to idle high brand new. he lowered it down..it woudl grind if you shifted gears..
Old Feb 17, 2003 | 05:27 PM
Bubba297's Avatar
The reverse limiter is preset at about 2800 rpms. If you are on flat ground or not under a load, you wont need much throttle and can do just fine. If you have to push the throttle much at all or against a load, it will hit the limiter and you wont go anywhere fast. The idle does need to be adjusted sometimes after break-in. Hope this helps. Bubba
Old Feb 17, 2003 | 06:23 PM
galljc's Avatar
Do you have a reverse override button? If so try pushing that and going in reverse.
Old Feb 18, 2003 | 11:32 AM
Thanks guys .... Yes, I do have a reverse overide button ... it still does it .... I didn't know the limit ws 2800RPMs ... thats good to know ... Now, my idle question .. *Sometimes* the bike will just diewhen comming to a stop .. Most of the time time idles just fine ....
Njrider1230
Jul 29, 2023 05:16 AM
SyTye
Sep 11, 2015 02:45 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Schneider
Jul 24, 2015 05:05 PM
