valve adjusting with 11:1 piston and stage 1 hotcam
done the break in process after installing 11:1 piston and stage 1 hotcam and had the valves set according to the specs on the sheets.is it just me or are they to loose.i had the rpm's up during the break in and they were rattling like crazy.when i adjust them can i tightem them up a little more than the specs say or will it damage the motor??[img]i/expressions/face-icon-small-confused.gif[/img]
Tony from Hotcams has answered this before. He says you can go .001 tighter. I have read where others who have set them tighter than that like .005 intake and .006 exhuast and have said they have had no problems. I personaly have set mine to .007 intake and .009 exhuast and it helps quiet them some. I'm going to go .006 and .008 next adjustment. I'll be doing that this coming weekend. [img]i/expressions/face-icon-small-smile.gif[/img] The tighter they get the sooner the adjustments need to be checked done as to not burn a valve. JMO
I got the same setup & went thru the same scenario. The valves, they were a banging.....try 006 intake & .008 exhaust, works nice! You'll notice in the instructions they say to adjust them between the recommended(very loose) to a little looser than stock(perfect). Most people seemed to have settled on the above settings either by experience or by word of mouth so there are many of us using those settings problem free. [img]i/expressions/face-icon-small-smile.gif[/img]
whitebread - howd you like the power increase with the 11:1 and stage 1 cam with no porting to the head ?
haven't rode it yet,trying to work out all the bugs and get the jetting and valves set right.after that i'll put around for a little bit and then get on it.can't wait
