valve adjusting with 11:1 piston and stage 1 hotcam
sounds like it will make big power increase ! anyone know where i could get the cheapest prices on hi comp pistons and an aftermarket cam ? I also wanna port my head but i think i ll wait to see how it runs with out porting if i do it. my reason is, trinityracing says Until you port it out, you're going backwards. Due to flow constraints in the Raptor's 5 valve head, porting the intake tract is critical - thanks thanks for the info guys
#18
#20
I have a Stage 2 Web cam, with the new valve springs, i get alot of valve noise. They have been adjusted 2 times and I havnt tried to adjust them again. Just accepted that the stage 2 cam will make noise. Is this right or am i heading down Memory lane with a top end job?
My Mods are:
Pro Flow filter
185,180 dyno jet kit
Stage 2 Web cam
11:1 Wiesco piston
Valve Spring kit
.5 bore
Big gun Header & exhaust
My Mods are:
Pro Flow filter
Stage 2 Web cam
11:1 Wiesco piston
Valve Spring kit
.5 bore
