valve adjusting with 11:1 piston and stage 1 hotcam
Old Feb 17, 2003 | 09:25 PM
whitebread's Avatar
Default valve adjusting with 11:1 piston and stage 1 hotcam
done the break in process after installing 11:1 piston and stage 1 hotcam and had the valves set according to the specs on the sheets.is it just me or are they to loose.i had the rpm's up during the break in and they were rattling like crazy.when i adjust them can i tightem them up a little more than the specs say or will it damage the motor??[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 17, 2003 | 10:02 PM
whitebread's Avatar
somebody answer,all the people in here with the same set up as me and nobody knows,somebody please!!!!!!
Old Feb 17, 2003 | 10:08 PM
wshrdskin's Avatar
Tony from Hotcams has answered this before. He says you can go .001 tighter. I have read where others who have set them tighter than that like .005 intake and .006 exhuast and have said they have had no problems. I personaly have set mine to .007 intake and .009 exhuast and it helps quiet them some. I'm going to go .006 and .008 next adjustment. I'll be doing that this coming weekend. [img]i/expressions/face-icon-small-smile.gif[/img] The tighter they get the sooner the adjustments need to be checked done as to not burn a valve. JMO
Old Feb 17, 2003 | 10:15 PM
whitebread's Avatar
i prochate it[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 17, 2003 | 11:21 PM
Chimmer's Avatar
I got the same setup & went thru the same scenario. The valves, they were a banging.....try 006 intake & .008 exhaust, works nice! You'll notice in the instructions they say to adjust them between the recommended(very loose) to a little looser than stock(perfect). Most people seemed to have settled on the above settings either by experience or by word of mouth so there are many of us using those settings problem free. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 18, 2003 | 01:58 PM
TriRap's Avatar
use the stock settings .004 in & .006 ex
Old Feb 18, 2003 | 02:07 PM
wildchild660R's Avatar
whitebread - howd you like the power increase with the 11:1 and stage 1 cam with no porting to the head ?
Old Feb 18, 2003 | 05:57 PM
whitebread's Avatar
haven't rode it yet,trying to work out all the bugs and get the jetting and valves set right.after that i'll put around for a little bit and then get on it.can't wait
Old Feb 18, 2003 | 06:00 PM
RoostItUp's Avatar
You'll like it! Especially when you see the Banshee your racing 2 quad lengths behind!! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 18, 2003 | 06:03 PM
whitebread's Avatar
they'll get a good view of the grimreaper sticker on my swingarm,if they catch a glimpse as i blow by.lol
