changing pred rear sproket
Old Feb 18, 2003 | 12:48 PM
Scotts88's Avatar
Default changing pred rear sproket
Well i ordered my 13 tooth front sprocket..should be in this week..but since i went with a 22' rear tire, i decided to change the rear one to 38 tooth. A little more low end grunt. ANyways..how do you change the rear? I mean is it just a matter of taking the wheel off..loosing the chain, then unbolting the sprocket? You dont have to do anything to the axle or hub do you??
Old Feb 18, 2003 | 12:50 PM
pleasure4qt's Avatar
You have it right Scott, that's all you do.
Old Feb 18, 2003 | 05:10 PM
Scotts88's Avatar
Thanks! Hopefully it will be pretty straight forward! My only concern is that im gonna have it geared too low.. but if my stang can handle the low gears..my bike can too! [img]i/expressions/face-icon-small-wink.gif[/img] lol
Old Feb 18, 2003 | 05:30 PM
SP700RACER's Avatar
You are going to have to remove the hub to get the stock sprocket off. No big deal though. only takes 5 or 10 minutes to change them out.
Old Feb 18, 2003 | 06:15 PM
Scotts88's Avatar
How does the hub come off? Remove the end cap and just unbolt it? i've never done this before..
Old Feb 18, 2003 | 06:39 PM
SP700RACER's Avatar
Removethe cap, remove the carter key, then unbolt it. no problem.
Bratman2
Aug 6, 2022 01:42 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Jul 29, 2015 10:57 PM
