Banshee revving high
Old Feb 18, 2003 | 07:54 PM
Wazzer's Avatar
Default Banshee revving high
My banshee is revving high when i give it a couple shots of the throttle. What's the deal? I'm getting frastrated, please help me.
Old Feb 18, 2003 | 08:00 PM
DaBeechMan's Avatar
sounds like your throttle is sticking, check your cable to make sure its all free. Maybe put some cable lube down between the sheeth and the cable. Make sure the cable as its going into the carb isnt bound up. If thats all cool you might even have an air leak
Old Feb 18, 2003 | 08:14 PM
Wazzer's Avatar
no, the throttle cable is new, and i checked for leaks, and that wasn't the problem. I don't no of anything else.
Old Feb 18, 2003 | 08:15 PM
Highfive's Avatar
Does it do it all the time? or just once it gets warmed up?
The cable should move freely enough if you don't have it running and you push the throttle all the way on and let it slam shut you should be able to hear the slides bottoming out in the carbs(tough with 2 I know)
You could be just jetted lean on the idle circuit but if no changes have been made and the cable moves freely definitely look for the air leak, this and difficulty cold starting are good indicators of a leak and they can quickly wear out a motor if you don't fix it.
Old Feb 18, 2003 | 08:17 PM
Highfive's Avatar
Whoops you beat me to the reply.
How did you check for leaks if you don't mind me asking? Pressure tester?
Old Feb 18, 2003 | 08:24 PM
Wazzer's Avatar
I tested by spraying choke cleaner all around, while it was idling.- messy, i know.
Old Feb 18, 2003 | 08:37 PM
Highfive's Avatar
Have you made sure the carbs are synced?
If not, sometimes one side will pull the other into a lean spot by being cracked too far open.
I have had trouble testing for leaks with the cleaner before, wasn't volatile enough to make a difference either way. One good indicator of a leak is the loss of change when adjusting the idle air screws but it's tougher too notice with the dual setup.
Does it have the stock carbs on it with the TORS setup?
Old Feb 18, 2003 | 08:49 PM
Wazzer's Avatar
yeah, the carbs are incync. about the carbs and tors, the guy i bought it off of said they were stock. do you think maybe the main jets and pilot jets are clogged? i don't know if that would make it rev high or not.
Old Feb 19, 2003 | 08:43 PM
snakes's Avatar
Check your cable adjustment. Their should be a rubber boot you can pull back, near the throttle.
Old Feb 21, 2003 | 02:29 AM
RaptorRacer1's Avatar
It sounds like you are really lean on your idle circuit. My raptor did the same thing when I didn't have the idle screws adjusted properly. I am not familiar with banshee carbs. If you have idle FUEL screws (engine side of carb), then turn them OUT 1/2 to 1 turn each to see if that helps. If you have idle AIR screws (airbox side of carb), then I think you need to turn them IN 1/2 to 1 turn. That should help. Good Luck.
RR1
