Carb Cables???
Old Feb 26, 2003 | 10:40 AM
jericho's Avatar
Default Carb Cables???
I am getting ready to take the carb off of my Predator to rejet and my questions is how do you take the 2 cables loose? They both have nuts on top but I do not want to mess with them until I know how they come off. THANKS!!!!!
Old Feb 26, 2003 | 12:54 PM
modquad's Avatar
You shouldn't have to take it all the way off, loosen the front clamp and rotate it 90 degrees.
Old Feb 26, 2003 | 01:58 PM
Crawdad's Avatar
If you do want to remove the carb completely though the accelerator cable which is the uppermost cable can be rmoved by pulling out the entire carb throttle valve. It comes out of the center of the carb by unscrewing the whole top assembly from the carb. That's the center cap that the cable screws down into. You don't need to mess with the adjustment nuts or you'll have to readjust those once you put it back together. You'll probably want to readjust those a little anyway if you have the entire carb out.
To remove the other cable which is the choke cable just loosen the larger nut on the bottom of the cable where it enters the carb and the choke valve will then come out.
If you're not comfortable messing with the adjusting nuts on the cables then you might be better off just rotating the carb to get to the jet like modqaud suggested.
Old Feb 26, 2003 | 05:45 PM
StevieD's Avatar
i know absolutely nothin about the predator, but to remove teh carb cable from the 400ex's carb, you gotta take a plastic cover off to remove the stopper at the end of the cable. maybe thats how the preditor works too?
Old Feb 26, 2003 | 06:27 PM
pleasure4qt's Avatar
"To remove the other cable which is the choke cable just loosen the larger nut on the bottom of the cable where it enters the carb and the choke valve will then come out.
If you're not comfortable messing with the adjusting nuts on the cables then you might be better off just rotating the carb to get to the jet like modqaud suggested."
To remove the throttle cable I removed the 3 screws from the side cover, opened the throttle wide open and slipped the cable around and removed the stopper and unhooked the cable and then screwed it out of the carb. Very simple if you have small fingers otherwise get the wife. *L*
Did anyone else have a really hard time removing the 4 float bowl screws and the 2 top screws on the carb? I had major problems and had to bring out the power tools. Tim the Tool man would of loved me.
Old Feb 26, 2003 | 09:54 PM
StevieD's Avatar
thats exactly what i did to get mine out
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
timster911
Jul 13, 2015 01:57 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
