electrical problem?
Old Feb 26, 2003 | 04:29 PM
ScoobysZ's Avatar
Default electrical problem?
I have a '83 big red 200. When it is idling the headlight is dim. As you rev it up it goes out? Also the electric start does not work, but if I hook it to a battery charger it will work. The battery is only a year old, is it bad already?
Old Feb 28, 2003 | 12:57 AM
dads's Avatar
sounds like a bsd batt.
Old Mar 11, 2003 | 09:34 PM
Nobody077's Avatar
If you have a Multimeter then check the voltage on your battery first let it charge on your charger on the lowest seting for a few hours, it should than be about 12v with the light off, then turn your headlight on, if the voltage drops below 10volts and/or drops quickly then the battery is done, a good fully charged battery should last longer than 15min with the headlight on. If the battery passes this test than check the voltage with the bike running, the voltage should be around 14v at rideing RPM's if it lower than your bikes not charging the battery good and you may need a new stator.
Old Mar 14, 2003 | 01:08 PM
Starky's Avatar
007, Where do you get parts for your 250SX. I have an 85 also that I want to fix up, but it's hard to find used parts. I know I could buy new, but I WANT TO KEEP THE PRICE DOWN.
Old Mar 14, 2003 | 05:43 PM
Nobody077's Avatar
I have been finding alot of good parts on Ebay, In the last few weeks I have got a new frontend(forks w-tripple clamps and front hub w-new brakes), a top-end kit, full gasket set, spare coil(new), and regulator for about $120 after shipping. Just keep your eyes open.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
