Does your DS650 pull?
Old Mar 3, 2003 | 09:07 PM
DeanB's Avatar
Default Does your DS650 pull?
My 2000 DS650 pulls to the right. Even before I rolled it and bent the right upper a-arm a 1/2" back, it pulled to the right. Before the roll, I set the alignment and the tire pressure. Is this normal for the DS?
I like to think that my right front suspension works better because it has more castor now. Now if I could only plow another big rock with the left side, I'll save hundreds of dollars over new upper a-arms. (joke)
Old Mar 3, 2003 | 09:37 PM
PUSHINTHELIMIT's Avatar
I have a similar problem, when I push the throttle mine pulls very hard forward or wherever it is pointed. Sometimes when I'm not paying attention I will end up in the pickers or somewhere off the trail in the woods because of this problem. Haa haa. [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 3, 2003 | 10:57 PM
lilnotts's Avatar
ya mine seems to pull, but maybe thats bcuz instead having a few inches of tire touchin the ground, i have over a foot of plastic, and you guys complain about twitchyness with tires, thats nothin compared to skis
Old Mar 3, 2003 | 11:28 PM
OBSESSED's Avatar
No, that is not normal.
Old Mar 4, 2003 | 01:49 AM
Knutz's Avatar
Check your tire pressures! Most likely the rear tires may have different pressures, causing a bad pull on any vehicle with an axle like that of a quad. Because of the extreme width of the DS, it's more noticable on it than other quads, and a slight difference will show itself more severely. All but one customer complaint I had about "pulling" was due to this. The one that wasn't, was due to the swing arm coming apart at the pivot, causing the swing arm to be at a slight angle.
Old Mar 4, 2003 | 01:55 AM
jetjock16's Avatar
dude, DEANB, i hope your not riding around at high speeds with that front end all out of whack, at least wear a helmet man! Im going to be recieving my ASR a-arms this week, if your in need of a right upper, maybe i could hook ya up.
Jetjock16
Old Mar 4, 2003 | 02:27 AM
DeanB's Avatar
Jetjock16
Thanks, but no thanks. I'm not willing to spend any money on the stock old style a-arms. Maybe I would consider the stock new style, if I was ever convinced that they fixed the caster. My options are just ride as is; I did reset the toe. This is most likely what I will do. Or buy ASR uppers. Somewhat cheap at $199, but still not getting what I really want, "wider". I love width, and honestly I have not heard of any aftermarket a-arms that are wider than what I want. But than again I want independent rear suspension too and I know I will never get that.
BTW, I always wear full gear. Sadly, I don't think my quad handles any worse now at 70mph than it did before I put on my 23" front tires.
Old Mar 4, 2003 | 09:10 AM
02BAJA's Avatar
Tire pressures are different. Does it everytime!!
Old Mar 4, 2003 | 09:35 AM
Wannaride's Avatar
Does it pull hard to one side when you are doing a wheelie?
Old Mar 4, 2003 | 10:07 PM
DeanB's Avatar
I couldn't tell you, me nor my quad are big on wheelies. It could be my worn, stock rear tires or my big hairy spare tire above my belt. You choose.
