Gearing 15x42 or 17x38
What size tires are you running, the 17/38 combo is the same gear ratio as running 22" tires with stock gears, so if you want the same hooh up as 22' tires but still run the 20" go with the 17/38.
try 15/40 with 20" tires, start in 2nd gear, wind her to about 6K and dump the clutch. You'll need heavy clutch springs. keep you nuts on the tank until you get going, or you'll flip, but you'll have a hell of a launch.
