HELP! reinstalled clutch, won't engage!
Old Mar 7, 2003 | 12:04 AM
Mjollnir's Avatar
Default HELP! reinstalled clutch, won't engage!
OK, I went to check my crankshaft studs for the stud update (not done on mine, but the bolts were tight). I reinstalled everything in the reverse order, but the top of the clutch pack, the part that the bolts go through to secure it, does not fully seat! I ran the bolts down to see if that cinched it up, but no dice! I can't pull my clutch in, though I didn't try very hard...
I'm good at cars, but I've never been inside a motorcycle engine before, until now. I'm not familiar with wet clutches...
What's the deal!? Help, I have a trip to Pismo scheduled for this weekend!
PLEASE HELP!
THanks,
Marc
Old Mar 7, 2003 | 12:48 AM
jigggawatt's Avatar
Try opening your bleed screw on the clutch master cylinder. You'll have to bleed it again. It may have tried to make up the adjustment and all of your fluid is in the slave . When you open the screw it should engage.
Old Mar 7, 2003 | 12:49 AM
jigggawatt's Avatar
Make that the screw on the slave cylinder
Old Mar 7, 2003 | 02:08 AM
Mjollnir's Avatar
Got if figured out. the last friction plate was stuck to the pressure plate, and when I put tht pressure plate on, the splines weren't lining up. Pretty sure that's teh problem. Thanks to Jaybr at "the other site".
Thanks for the input though!
Marc
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Minimod
Sep 10, 2015 09:20 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
