loseing weight on 500 scrambler
Old Mar 7, 2003 | 08:08 PM
trailblazer275's Avatar
Default loseing weight on 500 scrambler
what are some of the way's to lose some weight off of the big 500 . i already put pipe,silencer, some airbox mods and nerf bars , and front bumper and alliminum rims and razr tires on it but i whata lose more weight off of it. plz write back i need help with this
Old Mar 8, 2003 | 01:14 PM
swampdonkeykiller's Avatar
If you have racks remove them. Remove the tool kit holder. Not sure what else you can take off. The lights I guess if you never ride at night or only race it.
Old Mar 8, 2003 | 05:42 PM
Daransport's Avatar
It depends on what you are going to do with it afterwards. You could...remove the srarter, oil injector, steel front bumper, steel skid plate, air box, lighten fly wheel, remove all "dormant" wires, remove all unused brackets....ADD aluminum bars, front bumper, skid plate. I had my 400 at 389lbs.
Old Mar 8, 2003 | 10:05 PM
Alpine2's Avatar
you could get rid of the floor boards replace with foot pegs , get rid of the round sprocket guard change the swingarm with the hotseat one it is 7 pounds lighter replace the steering stem with the hotseat one it is lighter also ,but if you really want to get into it get someone to make a new frame from aluminium that would be a huge diff. replace all disks with vented ones
Old Mar 9, 2003 | 12:26 PM
i was just thining of takes some stuff off and replaceing it wit stuff thats lighter
Old Mar 10, 2003 | 10:44 PM
ajo771's Avatar
Remove the cooling fan and some of the shielding around the radiator. Add a "Wetter" agent to the coolant to increase its efficency, also consider a billet head that will run cooler. This will remove almost 20 lbs.
Old Mar 11, 2003 | 08:41 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
ride it 8 hours a day, seven days a week
you will lose weight
j/k
Im curious as well.
Old Mar 11, 2003 | 09:33 PM
scrambled6910's Avatar
If its a 500 4x4 get new struts and housings, lose the shaft...there oo 70lbs. But if not, get alum handle bars... chromoly A-arms, chromoly swing arm, hot seat axle, bit lighter...adjustable too. Ummm, if u like the starter, u can buy the hpd battery drops 11 lbs, but do some online research because that battery is an industry standard. They charge 149...ive seen the same one for like 30 bucks...Hope this helps.
Old Mar 18, 2003 | 12:01 PM
ajo771's Avatar
I've never seen new strut houses. Where did you find chromoly A-arms? Are they for the 4x4's?
exmotocrosser
Sep 13, 2019 06:12 AM
Robinhood
Dec 26, 2015 10:28 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
