will winch burn up on plow system?
Old Mar 9, 2003 | 12:16 AM
kylekomorowski's Avatar
Default will winch burn up on plow system?
i am using a warn 2.5ci winch, iam about going to buy a plow, my dealersaid the winch will burn up in no time, but i never heard of a such problem, someone please give me expirences or some input, i would like to go with the winch but if i need to the manual might have to do. My winch is gonna be on either way...
Old Mar 9, 2003 | 09:36 AM
Xovan's Avatar
I have a Moose Plow and a Warn 2000 and have had no trouble at all. It works flawlessly (sp) . I have used the heck out of it this year too. If this white stuff keeps falling I am going th have to use it today again. Oh well gives me a reason to ride the quad.
Good luck.
Old Mar 9, 2003 | 01:17 PM
02AC375's Avatar
I have used mine for 2 years so far and have had no problems. I have heard of some people using a shorter cable (6' or so) instead of the long one so that the cable does not get damaged. I never have, Before I get ready for the regular use season i unspool the cable and re tention it so that it is loaded equally. You should have no problems.
Old Mar 9, 2003 | 01:27 PM
AllorNothin's Avatar
I have the 60in Country plow on mine with the 2500 warn winch been using it for almost three years now. I haven't had any problems other then my switch going bad.
Old Mar 9, 2003 | 01:33 PM
also, i am debating between a country cycle or a moose plow, do both of these have springs to help from damaging stuff?, and what positions do both of the turn in beside stairght?, i appreciate the help
kyle
Old Mar 9, 2003 | 06:12 PM
Xovan's Avatar
My Moose has 2 holes on each side of the center and yes it has the tension springs however I did learn that you have to be careful when you angle the plow, because if the blade kicks you get a dent from the plow mount in the back side of plow. I think if you were moving along it could realy warp somthing but this is not a prob if the plow is straight.
Old Mar 27, 2003 | 11:59 AM
gman250's Avatar
Been plowing hard this winter with my A2000, no problem. But, like everything else about a quad, maitinence is the key. Every season, I'll give mine a "refit" much like described on at this link. (www.dirtyhowies.com/warn_wich.htm) Hopefully mine will never look as bad as the one on that web page! Doah!
Old Mar 27, 2003 | 12:59 PM
RaptorRy's Avatar
Winch no switch yes
Old Mar 28, 2003 | 08:38 AM
Kodiac400's Avatar
Hello. I have a warn 2000lbs and have been using it with my plow for 2 years. So far no problems. The only thing that I ever had to do with the winch was replace the switch.
Johnny Mac
Aug 15, 2019 03:13 PM
Oct 10, 2015 10:20 AM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
