Foul plug check
Old Apr 19, 2000 | 11:17 PM
Banshee28's Avatar
I have a 2000 banshee and I want to make sure i have good jetting. I know that i run it til it gets hot then shut it off and hold the throttle wide open, then check the plugs. Is this a good way to check them or some other way?
Old Apr 20, 2000 | 10:01 AM
sAyIt_fmf's Avatar
I guess from my experiances, the right way to check a plug would be to run the engine in about 3rd gear at a pretty good clip (half throttle should work).......Then pull in the clutch and hit the kill switch.....coast to a stop....and check the plugs......that way you know for sure that the reading was taken were the engine would normally be operating.....
Just starting the engine and letting it idle is almost always going to give you a rich looking affect on the plug...
Old Apr 20, 2000 | 12:42 PM
Banshee28's Avatar
My bike is stock except for pro circuit pipes, and a pro design with K&N's. Temp is 40-70(spring in NH) 30.14 barometric and 60% humidity.
200 mains,3rd groove needle clip position, air scew 2 turns out. Thanks for the help guys.
Old Apr 20, 2000 | 03:04 PM
sAyIt_fmf's Avatar
I would think that 200 main jets...which is stock...would be way too small for your ride...But if they work....they work....
I have the pro flo kit with fmf pipes, and I have to run 270's to get the jetting right.
Thats without the airbox lid
Old Apr 20, 2000 | 03:38 PM
Banshee28's Avatar
I didn't mean to confuse you about my jetting sAyIt_fmf, I have 200's in the stock setup, i am putting the pipes and prodesign on this weekend. I was going to go up at least a couple sizes.
Old Apr 20, 2000 | 03:41 PM
Banshee28's Avatar
I am putting my pipes and prodesign on this weekend, i didn't mean to confuse you that I had 200's in with pipes on. I am going to go up a couple jet sizes when I put my pipes on.
KimSJoh
14
Jul 18, 2015 07:20 PM
chammerbeck
Jul 17, 2015 08:06 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
D-Hagz
Jul 4, 2015 02:19 AM
