22" tires with stock gearing ... faster or slower
Old Mar 12, 2003 | 12:16 AM
Shadow11m's Avatar
Default 22" tires with stock gearing ... faster or slower
I recently added 22's and my DS feels super slow off the line ... is this my imagination?
Also I raced a guy with 22's prior to my 22's and I smoked him bad.
What gearing do I need to go with for the 22's to keep the initial acceleration?
What is the advantage of the 22's anyway ... I only have them because of a bargain that I got on ebay.
thanks for your help in advance![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 12, 2003 | 12:33 AM
SANDMAN430's Avatar
traction, more of a foot print. i run 15-43 with my 22' but that is in the sand. try a different front sprocket. when you went to 22" you geared up thus getting a higher top speed, but it will be harder for the engine to get there as quick. the smaller tires allowed the engine to rev quicker thus the faster acceloration. i don't know the right gear combo to get back to stock, some guys like the 14 front also
Old Mar 12, 2003 | 12:34 AM
Fourwheelphreek's Avatar
15-43 or 15-42
with the 22" tires you will lose on top end but have plenty bottom, this gearing will correct this
Old Mar 12, 2003 | 12:53 AM
Shadow11m's Avatar
thanks for the 411
I have researched some of the old messages ... this question comes up a lot.
I'm trying to decide btwn the 14 or 15 ... I do a lot of MX style ridding[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 12, 2003 | 08:54 AM
Wannaride's Avatar
Alright someone is out to lunch, If you increase you tire diameter, mathematics would prove the top speed would increase, Need to recalulate Fourwheelphreek? This is all dependant on if you can still turn the same rpm.
Old Mar 12, 2003 | 09:22 AM
glamisds650's Avatar
shadow, go here and plug in the #'s and you will see.
Old Mar 12, 2003 | 01:21 PM
HillbillyDS's Avatar
The 14 front sproket will be much harder on the chain, stay with the 15 up front & consider a 41 or 42 rear.
Old Jun 4, 2003 | 03:43 PM
TyreSpinner's Avatar
Does anyone make good cheap steel back sprockets in other sizes than 40 tooth??
Thanks
Old Jun 4, 2003 | 04:17 PM
fastone21's Avatar
sidewinder makes a good rear
Old Jun 4, 2003 | 06:21 PM
JEFFROE's Avatar
put a 14 front on with the stock 40 rear and you'll be all set.
