700 air mixture screw
Old Mar 12, 2003 | 04:17 PM
mcman's Avatar
Default 700 air mixture screw
Where do I drill?
Old Mar 13, 2003 | 01:00 AM
firemedic5586's Avatar
1} Pull the carb of the engine - can leave the choke and throtle cables attached.
3} The plug will be on the underside of the carb. Just in from the "Opening" that was in the boot on the engine side of the carb.
4} Its the only brass plug on the bottom of the carb and it does have a REAL small whole in the center of it. Its wide enough to slide
a 24 gauge IV needle into it IE: DARNED SKINNY. But does work nice as a pilot whole. And it is rather deep. I checked, then checked
and recheked again as I drilled mine out. Cuz The Polaris manual pics werent the best.
hOPE THIS HELPS
Old Mar 13, 2003 | 06:20 AM
mcman's Avatar
This is a large help. I was looking on the right side. Thanks
Old Mar 13, 2003 | 10:52 AM
spruce700's Avatar
What does this do for the quad? Performance?
Old Mar 13, 2003 | 06:37 PM
mcman's Avatar
It helps to smooth it out at idle to 1/4 throtle.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
