400ex makes a ticking noise
Old Mar 13, 2003 | 11:13 PM
fred600rr's Avatar
Default 400ex makes a ticking noise
I have a 99 440ex and it makes a ticking noise when iam in the gas hard but not till after iam passed half throttle. It sounds like its coming from the front of the engine. I heard it could be the oil pump going out. Any suggestion would be nice thanks
Old Mar 13, 2003 | 11:31 PM
CrAcKhEaD's Avatar
does it have a cam? check ur valves for adjustment
Old Mar 13, 2003 | 11:37 PM
chad400ex's Avatar
Adjust your valves.... If the ticking gets louder as your RPM's go up. Another possibility would be the cam chain, but I wouldn't think it would be that sloppy in there. You'd hear that mostly at idle. One way to check would be to unsrew the bolts on the cam chain tensioner. If it pops out about a quarter inch, it's okay, if not, you'll want to get it checked out.
Old Mar 13, 2003 | 11:52 PM
Milkweed's Avatar
I had the valves and cam chain adjusted and it went away!
Old Mar 14, 2003 | 12:57 AM
fred600rr's Avatar
i just had the valves adjusted so they should be fine and if it was the valves it would tick all the time not just past half throddle. so it think that the cam chaim might be sloppy iam waiting the the manual to check that out thanks for the responses
Old Mar 14, 2003 | 09:22 AM
RideRed420's Avatar
before my valve adjustment.........
it would tick a little when laying in the gas.........
so if i hear valve noise at a low idle then the cam chain is loose????????????
my 400ex has always idled super low since it was new,
now at low idle it starts ticking,
but if i hit the gas it stops.........
i idled it up a little (very little) and it doesn't do it anymore........
whats up with that??
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
D-Hagz
Jul 4, 2015 02:19 AM
