Raptor with Yoshimura pipe
Old Mar 15, 2003 | 02:49 PM
FX1660R's Avatar
Default Raptor with Yoshimura pipe
ok here's my question my heads pipe come red on idle is it normal ??
i dynoed my bike i have 47hp on dyno the byke pull hard no probleme at all ...i think ;-)))
complete yoshi pro comp
i jetted #152.5/155
two 1¾" on top lid
with no snorkel
factory filter
and finaly mixture screw 1½ turn out
everything else is stock
thank's
Old Mar 15, 2003 | 02:52 PM
Guest
Guest
Posts: n/a
sounds about right..going from the dyno info from FTWs dyno sheets...
Old Mar 15, 2003 | 02:54 PM
FISHER1648's Avatar
Mine does the same. Appaerently thats normal but you should verify that youre jetted correctly. From what I hear, if the head pipes end up blue when cool they are getting too hot and the mixture is lean. When mine cool they are kind of a combination of copper/gold. Not sure if this is accurate or not but seems reasonable.
FX1660R's Avatar
yes i think the number's are good but my concern are for my head pipe's comming red on idle ;-((
Old Mar 15, 2003 | 03:01 PM
FISHER1648's Avatar
I just went out and took a look - the color is more copper/gold than anything. Not really any blue to speak of.
Old Mar 15, 2003 | 03:08 PM
FX1660R's Avatar
im probably lean
mine is more shiny sylver with little blue
Old Mar 15, 2003 | 10:00 PM
sixsixT's Avatar
Your mixture screws should be 3 turns out.You will or have probably experienced a lot of popping on deceleration because your idle mix. is way lean.I think the directions say 1 1/2 but that is wrong. This will help with the glowing pipe also, but it is normal for them to glow a little at idle.
Old Mar 15, 2003 | 11:02 PM
rc3's Avatar
rc3
I put that same system on my bike and I went up on the pilot jet and I put the DYNO JET Needles in it, I would really try a bigger Pilot Jet,
Old Mar 16, 2003 | 12:11 AM
FX1660R's Avatar
Thank's
great advice all
i'll do a try with the mixture screws and see what appens
yes i have a lot of popping when i slow down and it often stall
Old Mar 16, 2003 | 01:15 AM
RaptorRacer1's Avatar
The directions form Yosh are WRONG. Like others said, you need to turn the idle mixture screws out more. Try 2 1/2 on the L carb, and 3 on the R carb. This should be very close. It is normal to see the red glowing pipes at night or in low light, but it should not really be visible during the day. The popping on decelleration is also due to a lean condition in the idle circuit. This will clear up as you turn out the screws. You will know that you've gone too far out if your idle drops really low when you pull in the cluch on decelleration and the engine seems like it wants to shut off. You may try going up to 25 pilots. Good luck!
RR1
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
