What octane with 12.5:1 piston?
Old Mar 15, 2003 | 10:17 PM
Birdoprey's Avatar
Default What octane with 12.5:1 piston?
I bought a JE 12.5:1 piston(used, w/ rings, pin, and clips) and was wondering what octane i would need to run in my DS w/ stk cams, bore and head? How 'bout with RWR sport cams?(i know the comp drops when running a longer duration). I really hate to have my DS a race gas only bike, though i don't mind running 93(the best i can redilly get ahold of) as well as some type of octane booster(i know they don't up it much).
How 'bout i put it another way, whats the most comp i can run(w/ stk cams as well as w/ the sport cams) and still use 93 octane? I may have to modify the piston i bought....
Old Mar 15, 2003 | 10:20 PM
PUSHINTHELIMIT's Avatar
Your not going to be able to run 93 octane with a 12.5:1 piston. Need to go up but I'm not sure how much.
Old Mar 15, 2003 | 10:25 PM
FastYellow650's Avatar
im running methanol in mine with a 12.5, it not hard to convert it over to methanol, its an ideal you might think about
Old Mar 15, 2003 | 10:27 PM
Birdoprey's Avatar
Yeah, i did'nt think so. Mainly wondering how much i need to drop it to be able to run the 93...
Old Mar 15, 2003 | 10:30 PM
Birdoprey's Avatar
Hmmm...had'nt thought of that. The TM45 carb i bought already has jets for running alcohol(also have jets for gasoline), are they simmilar? Where would one get the methanol, and how expensive is it? I don't wanna mess with anything that is hard to come by. Is it high maintenance?(if so, what)
Old Mar 15, 2003 | 10:36 PM
I thought 11:1 or 11.5:1 was about the limit for 93 octane.
Old Mar 15, 2003 | 10:38 PM
dsr's Avatar
dsr
running mine on 110
Old Mar 16, 2003 | 02:10 AM
BajaDS650's Avatar
Couldn't you run AVgas with it?? You can get 100octane avgas for just about the same price as premium. Just a thought, many people are against avgas, and others swear by it. If I ever go higher compression I am going to try it out.
Old Mar 16, 2003 | 01:43 PM
you sould be albe to get it at a local race track, dirt ovel or drag strip, i got a 55 gallon drum for 65 bucks, im not sure how much the goes for now, i got my last summer, they say that there is alot of maintance but i havnt noiced any problems running with it, some will say you have to purge the carb after a day of use, i normally will do it after a weekend of riding, i dont do many one day trips, cause the alcohol is drier than gas youll need to add a top lube to it to, you can find some already mixed so you dont have to worry about mixing it correctly, plus you can get an scent added so that it doesnt burn your eyes if your behind it or you buddies sence they will be behind ya
Old Mar 16, 2003 | 08:11 PM
BigWaynester's Avatar
My 12.5 piston runs great on 100 oct. race gas[img]i/expressions/face-icon-small-smile.gif[/img]
