How many links in Scrambler chain?
Old Mar 15, 2003 | 10:48 PM
PolarisPower500's Avatar
Default How many links in Scrambler chain?
I have a '99 Scrambler 500 4x4 and it is the only quad Dennis Kirk does not list the # of links. They say it has a 13 front and 36 rear sprockets. I'm going to get a DID chain, but how many links? What kind of sprocket should I get? Kirk doesn't carry many Polaris sprockets.
Old Mar 15, 2003 | 11:00 PM
hannahj's Avatar
i think it is around 76 my dealer just gave me a 100link so i cut of the rest its not hardwith a grinder. YOU should tighten your chain so you can barely move it when you put it back on i had mine real loose and i broke my new sproket. I went down a tooth to a 12 for the front for better low end i called a polaris dealership they said it shouldnt hurt the four wheeler drive system. I had a sunstar on but i broke the teeth so they i bought the 12t one and they had was emgo for $15 but the sunstar are supposed to be pretty good the only reason i broke it was brcase my chain was to loose. hope that helps
Old Mar 15, 2003 | 11:02 PM
hannahj's Avatar
go to hotseatperformance.com they have sunstar sprockets and chains andthe price
Old Mar 16, 2003 | 12:32 AM
Thanks for the advise. My stock sprockets are worn but were never affected by a loose chain. In my opinion, any good sprocket should not get broken teeth from a loose chain. The Scrambler is very likely to break the tranny case after a jump or even in thick mud with a tight chain.
fordfaithful21
Dec 7, 2015 05:52 PM
bigred20653
Oct 2, 2015 10:05 AM
bvolks
Sep 13, 2015 12:57 PM
1000gade
Sep 9, 2015 03:35 PM
bmark0610
Sep 7, 2015 09:42 PM
