Oil level keeps increasing... why?
Old Mar 15, 2003 | 10:58 PM
looking's Avatar
Default Oil level keeps increasing... why?
The oil level on my '03 Sportsman 400 is increasing. I read in the manual somewhere it was due to riding in cold condtions.
I have done most of my recent riding in cold weather and snow. The manual says to replace the oil at the first sight of increase because there is water in the oil. My question: do all you guys up north experience this? Do you change your oil more frequently as a result?
Old Mar 15, 2003 | 11:51 PM
hoover650's Avatar
Water pump seal is out. Happened to my DS650....get it fixed immediately
Old Mar 16, 2003 | 12:01 AM
looking's Avatar
It is a brand new machine and the radiator fluid level has not changed... any other ideas?
Old Mar 16, 2003 | 02:52 AM
scrambled6910's Avatar
Condensation on the inside of the tank, heat machine up, change oil, filter and clean lines and screen. Change as many times as neccessary, There is definately water building up at the bottom of the tank, and that needs to be fixed. Radiator leak sounds right too tho.
Old Mar 16, 2003 | 08:58 AM
NovaKaw650's Avatar
Check for a gas smell in the oil. Your float level may be too high or the needle is leaking by.
Old Mar 16, 2003 | 09:18 AM
sugarhead's Avatar
It could be several things wrong w it.Did u forget to turn off the fuel tap,if not an your floats,needle s stcking are too high it could dump gas into the bottom end.also if u rode thru snow water,condensation could cause that.Last but not least a wate pump seal can go but from what You stated it doesnt sound like tht.Either way drain the oil ,new filters etc an inspect it n the pan smell it for gas or look for milky white stuff whcih is water/coolant.Good luck bud an hope this helps!.
Beeline08
Nov 11, 2016 04:00 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
panicmanic
Sep 28, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
