I need professional advice on Blaster Paddles.
Old Mar 16, 2003 | 01:17 AM
TrailRidinBlaster's Avatar
Default I need professional advice on Blaster Paddles.
I'm putting a Toomey on my Blaster and need advice on what paddles will best accomodate it. Is the clearance going to be OK with 20's or Should I go bigger. What wheel size is the best? I hope someone out there can help me out.
Thanks!!
2003 Yamaha Blaster
1986 Kawasaki KLR 250
Old Mar 25, 2003 | 06:52 PM
BLASTERDEVIL2's Avatar
i have geckos but i want to try haulers
Old Mar 25, 2003 | 08:05 PM
YFZRacer's Avatar
id stick with 20s or if you want to go to 22s you would have to gear down lots
haulers seem to be the most popular drag tire but you might want more of a angle paddle tire for more conventional riding geckos look ok there is lots of other good choices out there 2 hope that helps a bit lata
-cory
Old Mar 26, 2003 | 09:13 PM
maddog56's Avatar
skip on the 22's, they will just be too big. the gearing change, as was said, would be extreme, and you would lose a lot of top end. 20's would be fine, i run 20's on my stock raptor. i have a 10 paddle setup on 10" wheels, and im very happy. i have xtreme haulers, and i havent found a better sand tire out there. many people i know have switched, just after seeing me run. dont go with too many paddles, you will get bogged down also. probably a 9 paddle setup. as far as wheel size, the bigger the better. 10 is great, 9 is good, 8 is kind of small. if you are buying new wheels go with 10". if you dont have a set of at least 9" wheels to put them on, you should get some.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
