Do we really need to run Synthetic oil in new ATV's?
Old Mar 16, 2003 | 01:20 PM
MudMasterGeneral's Avatar
Default Do we really need to run Synthetic oil in new ATV's?
At $9.00 a quart I can't afford to change oil as often as I would like to. Are there any alternatives?
Old Mar 16, 2003 | 02:30 PM
95sport400's Avatar
Amsoil 0W-40 Formula 4-Stroke is only $6.50 a quart retail. You can get it for less by becoming a dealer, a preferred customer, or if you know a dealer well enough that he'll give you a discount. One of the great advantages of synthetic is that you don't have to change it as often. The extra protection plus increased fuel economy makes it well worth the little extra expense. Especially when you look at the price of a new quad. Amsoil also has excellent filters for most applications and a great inexpensive synthetic grease.
Old Mar 18, 2003 | 09:32 PM
motorman's Avatar
the syn oil will take more temp before breaking down. if it came with syn there was a good reason. mobil 1 also sells 4 stroke bike/atv oil
Old Mar 19, 2003 | 12:15 PM
scramblered's Avatar
always better to run the brake-in period with the factory oil it came with,for a 2 stroke better for the rings and cylinders walls,pistons,as the running time increase heat will fade way a little with time after brake-in,but again it all depend how hard or not you'll first run your new engine,synthetic stuff is all about top protection and engine lifetime,performances wise,there is not much.
Old Mar 19, 2003 | 08:43 PM
bjn644's Avatar
I am using Mobil 1 0W40, under $5.00 a qt. at Autozone, I'll bet it's even better than the Polaris stuff.
Old Mar 19, 2003 | 08:54 PM
95sport400's Avatar
Scramblered is right about leaving the original oil in for break-in. Then put in synthetic. Synthetic also allows your motor to run a little cooler due to less internal friction. Another great thing about synthetic; if you have one newer vehicle and one older one you don't care as much about (new SUV, old plow truck; or new quad, old lawn tractor; you get the idea); you can take the synthetic drain oil from your newer vehicle, filter it with a coffee filter and it'll be as good as any regular oil to throw in your older motor.
cornermike
Aug 10, 2016 06:47 AM
Alex G.
Sep 19, 2015 06:34 PM
Haakon
Aug 24, 2015 01:54 PM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
toonces
Jul 31, 2015 09:27 AM
