Raptor Axle Nut - Help
Old Mar 16, 2003 | 11:18 PM
jpoggi660r's Avatar
Default Raptor Axle Nut - Help
Can someone tell me the proper procedure to tighten the Axle Nuts on the stock Raptor Axle?
It seems like no matter what I do after 1-2 rides they come loose. I didn't have this problem from the factory but recently replaced my axle bearings so I'm sure it is something I'm doing wrong.
Please Advise,
Jason
Old Mar 16, 2003 | 11:35 PM
RepTaR660r's Avatar
OK, heres what u do.... Get you something and put underneath the swingarm so that the rear wheels will be up off the ground. Next, thread the first nut all the way up against the brake hub and the put you a 50mm wrench or a pipewrench on the nut and rest the end of it against the ground. Next, get on the bike, crank it up, put it in reverse, hold the clutch in and rev it up to say..... 9 grand, then drop the clutch on it. There you have it, a tight axle nut. Simply repeat for the next nut. Have Fun!!!!
Old Mar 16, 2003 | 11:44 PM
Droopy's Avatar
There is a torque spec. for those two nuts. You have to use a special tool for it to adapt to the torque wrench though. You also have to use a formula to figure out the specified torque due to wrench lenth ect. If you take some lock-tight though and a big pipe wrench it should do the job.
Old Mar 17, 2003 | 12:01 AM
RaptorOwner's Avatar
This is what I got - Raptor Manual
Old Mar 17, 2003 | 12:48 AM
RaptorForever's Avatar
Check out this link. I bought this wrench to fit a 1/2" socket wrench or torque wrench. It worked well.
e-bay item seller is the manufacturer
Old Mar 17, 2003 | 12:58 AM
RSO660R's Avatar
Ummm you left out one step.
Explain to wife why pipe wrench flew through the living room wall while trying to tighten locknut
[Was quoting reptar660r]
Old Mar 17, 2003 | 03:26 AM
XxDumontRaptorxX's Avatar
LMAO at the two posts about the reverse thing. Good idea though!
Old Mar 17, 2003 | 04:41 AM
McFly's Avatar
The last thing you want to do is strip the thread on either your axle or your lock nuts.
Lock tight, plenty of sweat, and maby a bit of blood is the only answer.
Old Mar 17, 2003 | 09:09 AM
garyc660R's Avatar
Originally posted by: McFly
The last thing you want to do is strip the thread on either your axle or your lock nuts.Lock tight, plenty of sweat, and maby a bit of blood is the only answer.
If the axle nuts don't get a good cussing, along with some beer and blood, they will loosen right back up!
garyc660R's Avatar
A joke right? Right?
