just want to clear this up but....
Guest
Posts: n/a
Last time I was out riding some dumb AZZ told me that I can't mix normal pump gass with race gas or it will "gernade"my top end... Is this true? He told me to completely drain out my gas tank of the old gas before putting in like 110 gas..
and what could happen if YOu mix the premix with too much oil in it.. whats the worst that could happen say if you used like 14 to 1 or some stuff?
thanks
liquidsand
thanks
liquidsand
I've been told by a VP dealer that you cant mix VP race fuel with pump fuel. I use Unocal 110 and that can be mixed with pump fuel. If you put too much premix oil in your fuel, it will displace the gas causing a lean condition.
No problems, just average the octanes to get the one you want.
Too much 2- stroke oil and you will foul plugs and run like crap, but unless you have a ton I am pretty sure you won't damage anything.
Good Luck
Good Luck
MikeyBoyesq
Aug 10, 2015 11:11 AM
