cat axles
Old Mar 18, 2003 | 12:35 AM
jbird's Avatar
Default cat axles
I have heard of some problems with arctic cat cv axles.Is this a weak point on cats?Haven't had big problems with mine yet.One ripped boot that I blamed for my failure.Should I be worried?
Old Mar 18, 2003 | 04:15 AM
Fango's Avatar
Default cat axles
It seems to be more of a problem with the '02 and '03 machines. I really haven't heard of many problems with the older ones. Especially as of late...but if you notice that most of the problems have occured with lifted machines with big rubber and very aggressive riding.
I would like to know if AC used a different axle manufacturer on the later year machines??!!
Old Mar 21, 2003 | 11:41 AM
bbertram's Avatar
Default cat axles
The problem is with IRS, its not designed for big tires and aggresive riding. The older models did not have IRS so you can't compare them, not the same. Keep it stock or buy a P650.
Old Mar 21, 2003 | 09:40 PM
Cat500i's Avatar
Default cat axles
This is the Arctic Cat forum, not Kawasucki.
Old Mar 21, 2003 | 11:46 PM
jbird's Avatar
Default cat axles
Sound like the large models with irs have already maxed out the joint angle from the factory to get maximum ground clearence.Anyone had problems lifting the 250 or 300cc machines?These shafts are not angled very much from the factory.
Old Mar 22, 2003 | 01:32 AM
Fango's Avatar
Default cat axles
Originally posted by: bbertram
buy a P650.
What do you work for Kawi now BERTRAM??
Old Mar 23, 2003 | 12:04 PM
Cat500i's Avatar
Default cat axles
I think the inner joint angle is at its max when stock. I rode a few times before adding the lift and didn't have any trouble. The first time I rode with the lift I busted the axle. I repaired it and went riding again and busted the other side. The lift is off now. Anybody want to buy one, its for sale, cheap.
bberchump--go back to the kawi forum.
Old Mar 24, 2003 | 09:39 AM
Olddirtybastard's Avatar
Default cat axles
I broke an axle 6 miles after putting on a lift. I took the lift off and rode all day yesterday with no problems. You need Gorilla axles to run the lift.
Old Mar 25, 2003 | 09:51 AM
sxr6's Avatar
Default cat axles
The 300's don't have the steep angle but they too will bind with to much lift, I wouldn't go over 1 1/2" lift on them & you shpuld be all right, mines been good for 2000miles now with that much & no problems. You can take off the shock & turn your axles to see the max lift you can put on.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
