sprocket size>?
Old Mar 19, 2003 | 09:15 PM
Guest
Guest
Posts: n/a
Default sprocket size>?
This may be a simple question but I all ways get a different answer ever time I ask..
The bigger the rear sprocket = ? more top speed or what?
How about the smaller the rear sprocket (less teeth)... what good does that do.
Right now I think mine is 41 teeth..Whats this for.
Is there a big difference between 40 teeth and 41 teeth because I have both laying around the garage...
thanks guys
Old Mar 19, 2003 | 09:41 PM
RacinJason's Avatar
Bigger in front faster mph
Bigger in back slower mph
For every three tooth change at rear=1tooth at front
ex.14-43=13-40
Old Mar 19, 2003 | 09:54 PM
Guest
Guest
Posts: n/a
lets assume that the front sprocket size stays the same... and I only change the rear sprocket
iamchad2k5's Avatar
smaller rear makes the top speed faster, the bigger it is, it has bigger acceleration. the smaller, the faster. for front, the bigger the higher top speed. and smaller, better acceleration. when you change the rear sprocket, 1 or 2 teeth doesnt make too big of a difference. but when you change the front, you notice one tooth or 2 difference a lot more. like, lets say you have a 15 up front, and 41 in rear, and it went 70. you go to a 40 in rear, it will go about 72. there is a calculator at go to blue trax. it is blue trax.com, but add another "x."
Old Mar 19, 2003 | 11:06 PM
RaptorKing660's Avatar
Bigger front sprocket- Less accel, more top speed.
Smaller front sprocket-more accel, less top speed.
Bigger back sprocket-More accel, less top end.
Smaller back sprocket- More top speed, less accel.
Old Mar 19, 2003 | 11:23 PM
FISHER1648's Avatar
Check out the ratio chart at www.sidewindersprockets.com. -or- Simply divide the rear # of teeth by the front # of teeth to get your ratio (#rear/#front). when you change the number of teeth on the front or rear, the ratio changes. If that ratio increases - less top speed, more "grunt". if it decreases - more top speed, less "grunt".
It's all in the numbers.....
Old Mar 20, 2003 | 03:04 AM
Guest
Guest
Posts: n/a
great...thnx for the info...!
Old Mar 20, 2003 | 10:48 PM
RepTaR660r's Avatar
If you have the power to pull a taller gear then you will accelerate faster. Theres nothing you can say to make me change my mind about that.
Old Mar 21, 2003 | 10:00 AM
garyc660R's Avatar
A agree. Also, if you gear for more top speed, and can't PULL the gearing, one could actually loose top speed..[img]i/expressions/face-icon-small-wink.gif[/img].
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
