Winch Size
Old Mar 20, 2003 | 09:58 AM
ChiChi's Avatar
Default Winch Size
I have an Eiger 400 Auto and am looking to get a winch and plow. I'm not sure what size winch would be sufficient. Is there any reason to get a 2500 or a 3000 lb. winch. Would a 2000 or 1500 be sufficient? The Quad weighs only 600 lbs. What is the use of getting a 2g winch? I do plan on using it for other pulling chores such as pulling small logs, etc. Thanks
Old Mar 20, 2003 | 10:22 AM
stubblejumper's Avatar
Default Winch Size
I would get at least a 2000lb winch as I have seen even the 2000lb units work very hard to free badly stuck quads.The suction of breaking a quad free of the mud can result in much more force than the quads weight being required.
Old Mar 20, 2003 | 03:45 PM
action450s's Avatar
Default Winch Size
You will want at least a 2000 lb for good pulling power against the suction of mud/bog. I have a warn 2000, but would like to upgrade to a 3000lb.
Old Mar 20, 2003 | 05:22 PM
thud's Avatar
Default Winch Size
Get yourself a 2000lb winch. From past posts it appears that a 2500lb winch wont pull anymore then a 2000lb because an ATV electrical system cant supply the needed amps to take advantage of a 2500lb winches increased pulling power. I have my doubts that even a 2000lb winch pulls a full 2000lbs for the same reason. If you dont think a 2k winch will be enough for you, get a pully block ($20) to double the winches pulling power.
Old Mar 20, 2003 | 05:38 PM
Specta's Avatar
Default Winch Size
For a vehicle, we used to figure twice the vehicle weight would be a place to start. Never buy the smallest, it will let you down more than once.
The pull rating is with the cable all the way out and the cable winding up on a bare spool. I would also get a tree saver and a ****** block. That will double your pulling power, it will be easier on your electrical system. Another reason for a heavier winch, it doesn't work as hard.
Old Mar 21, 2003 | 12:58 AM
ChiChi's Avatar
Default Winch Size
Thanks for all the replys. You guys made my decision that much easier [img]i/expressions/face-icon-small-smile.gif[/img]
Joe
Old Mar 23, 2003 | 08:37 AM
macgiver's Avatar
Default Winch Size
i have the ramsey 3000lb i love it, plenty of pullin power. it blows the warren 2000 and 2500 away. i got it with the wireless romote
Johnny Mac
Aug 15, 2019 03:13 PM
Levi Enstad
Sep 26, 2015 08:00 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
