Need help, initial jetting a TM45
Old Mar 20, 2003 | 07:57 PM
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Default Need help, initial jetting a TM45
You guys could really save me some cash on the dyno if you could give me a ballpark starting point for jetting the 45... I have a set of large/upper RPM cams, drag ported head, oversized valves, 14:1 piston, trinity exhaust, TM45, clamp-on K&N, RWR ignition.... All this is coming together at one time, so I haven`t got a clue on a starting point. This also broke me financially and can`t afford a whole lot of dyno time, whgich is where the experience from you all would be VERY helpful!!!
Old Mar 20, 2003 | 08:49 PM
Hightower's Avatar
I would recommend the richest needle #95 at 5th groove, get a variety of pilots up to 55, and several mains up to maybe 165 - possibly higher even.
use the tuning manual instructions that came with the carb - they are pretty well written and easily understood. work on each circuit individually.
Old Mar 21, 2003 | 04:25 PM
ThePunisher's Avatar
What is you altitude there? I would start with a 152.5 main and leave your pilot alone. Go with the #95 needle in the middle clip. If you are clost to sea level the odds are you are going to end up running a 155 or 157.5 main. I highly doubt you will ever need to go over a 160 main though. And you are definatley going to need to run at least a 105 octane fuel.
Old Mar 21, 2003 | 08:19 PM
Forcefed's Avatar
Thanks for the help....I know better than to not post elevation...brain fart...800ft and an average temp of 70 deg. I will be running C-14 or C-16. I unfortunately did not purchase the carb through Woods so I didn`t get a tuning guide. But I have a pretty good understanding of how to adjust each fuel delivery circuit in the carb. I really appreciate the starting point!!! One more quick question though, since this carb did not come set-up for a DS, which of the three ports on the outside of the carb need to be plugged off? There are two (stacked vertically) on one side, and a solo port above the fuel inlet tube.....do they all get plugged, or all open, or whats the skinny?
Old Mar 21, 2003 | 11:59 PM
DuneMe's Avatar
Check This out. (Tuning manual)
I run the 45 pilot without accl. pump. 150 main jet (4000' elevation.) I would probably run a 152.5 at sea level (or 800')
That tuning manual is great.
I would start with the pilot jet. I know this sounds weird but, it is always open so a larger pilot will change you main jet (slightly).
If it doesn't start easily go to a larger pilot. If the mixture screw doesn't do anything go to a larger pilot.
Start fat and read your plug(s). Shouldn't take too long.
Old Apr 16, 2003 | 08:39 PM
DSJOBBER's Avatar
Ok first if its a bigger carb i.e. the diameter of the opening than why the smaller jet size? This will be the next investment once I install the RWR clutch springs that I have sitting in the garage. Please enlighten me someone.
Old Apr 17, 2003 | 12:13 PM
Forcefed's Avatar
The jets that are used in the OEm carb are a different type than the jets used in the TM45. If I`m not mistaken, a 200 Main in the OEm carb does not flow the same amount of fuel as a 200 main in the 45...I wouldn`t compare these recommendations with an OEM carb, kinda apples and oranges.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Sep 17, 2015 03:06 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
