Slip on pipe on 02 Scambler 500 need help PLEASE!
Old Mar 21, 2003 | 06:03 PM
ccole99's Avatar
Default Slip on pipe on 02 Scambler 500 need help PLEASE!
A buddy of mine just bought a WB E series slip on pipe for his 02 Scrambler 500 and we need a starting point on the jetting. He is also going to run a uni filter so if anyone could help with a starting point that would be great. Even if you don't have the same pipe but just a slip on give what jets you are running. Thanks for your time and help.
Old Mar 21, 2003 | 08:54 PM
Alpine2's Avatar
160 is all you will need you could most likely get by with the stock 155 becusae they are a little rich from the factory this would be from 1500 feet to sea level you never said your altitude.
take it for a run if you are faster at 3/4 throttle than at full throttle you are lean on the main jet if you get a slight stumble at full throttle you are rich so go back one size on the jet .
if your stock jet is a 155 get a 170 ,165 ,160 they are cheap so what ever your stock size is get the 3 next larger that would be all you will need for jetting even with airbox modifications
Hope this helps. If ya need anymore help just let me know I have been through the whole thing before
Old Mar 21, 2003 | 11:27 PM
KevinM's Avatar
Like Alpine said, they are rich from the factory, 160 will be plenty.
Old Mar 22, 2003 | 12:17 AM
ccole99's Avatar
Thanks alot guys. This will help alot. Thanks again.
Jeff Roper
Feb 1, 2022 11:48 AM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
greg86hd
Sep 16, 2015 12:32 AM
Brandon400
Sep 5, 2015 08:44 PM
