POPPING & BACKFIRE
Old Mar 21, 2003 | 11:57 PM
IMPERIAL's Avatar
Default POPPING & BACKFIRE
HAD MY JETTS PUT IN TODAY. NOW MY RAPTOR IS POPPING OUT THE BACK AND BACKFIRES. WHAT TO DO TAKE BACK TO SHOP OR IT WOULD STOP[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 22, 2003 | 12:05 AM
sixsixT's Avatar
Is it popping when you give it gas or when you let off? Do you know what jets they put in a what other adjustments were done to the carbs.?
Old Mar 22, 2003 | 01:55 AM
IMPERIAL's Avatar
SIX SIX T WHEN I LET OFF THE GAS MOSTLY. SOMETIMES WHEN I HIT THE GAS IT SEEMS LIKE IT'S BOGGING DOWN.
Old Mar 22, 2003 | 01:33 PM
RaptorRacer1's Avatar
To fix the popping when you let off the gas you need to turn your idle mixture screws (on the front bottom of your carm) out about 1/2 more turn each. That should help with the popping on decelleration. As for the bogging when you hit the throttle, try raising your needle clips one notch. You may be too rich in the midrange. I am just quessing on this one.
Did your dealer do the rejetting? It sounds like they have no idea how to jet a Raptor. I had the same problem with my dealer. I got a new Yosh pipe and spent over $200 in labor costs with my dealer because they could not get it jetted right. Finally I decided to do it myself. It takes time and patience, but when you get it just right - it is worth every hour you spent.
My advice - do a search on here for "Jetting" and see what has worked for others with similar mods to yours. Good Luck!
RR1
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
