wide tires
Old Mar 23, 2003 | 01:57 PM
Justin327's Avatar
Default wide tires
can anyone tell me the widest tires i can run on the front of a 500 magnum 4x4 without lifts or spacers??
Old Mar 23, 2003 | 02:05 PM
Scotts88's Avatar
Default wide tires
Not sure of what size tires, but just wanted to say nice to see somone else from Nova Scotia! Welcome!
Old Mar 24, 2003 | 09:41 PM
NGK425's Avatar
Default wide tires
good question, I have an expedition with the same chasis & front end and would like to know the same thing.
here are my thoughts so far. stock rims up front have, what I think is an inside offset of 5". Even though the rim is stamped a 6" rim, there is an inside offset of 5" and an outside offset of 2". there seems to be about a 1/2" space between the right tie rod end and the inside of the stock right front tire. The dunlop stock tire (25x8x12) measures 7" wide at the top. What I want to do, but am not sure of, is buy a C series aluminum rim with a (4" inside + 3" outside) offset so I can put a tire that measures 9" at the top on the front and not lose or gain any space between the new tire and right tie rod. this is the widest tire I think you can put on your magnum and my xpedition but I have yet to have anyone tell me if this will work. From what I can tell, there is no way a 9" wide tire is going on a stock rim without rubbing. If someone out there knows the answer to this, let us know....
thanks
Old Mar 25, 2003 | 08:28 AM
mtpockets's Avatar
Default wide tires
26" tall
9.5" wide
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
