380cc big bore kit for 250x
Old Mar 25, 2003 | 05:19 PM
250xRKrider's Avatar
Default 380cc big bore kit for 250x
i need to know where i can get a 380cc big bore kit for my 250x. how fast will it make my quad, and can it outrun a z400.your help is greatly apreciated.[img]i/expressions/face-icon-small-smile.gif[/img]
trx250x
supertrap exhaust
durablue axle
nerf bars
race cut fenders
uni air filter
Old Mar 25, 2003 | 06:53 PM
300exRiderJay's Avatar
i dont know about 380 but i know powroll has some big kits. check o ut there site at www.powroll.com
Old Mar 25, 2003 | 08:09 PM
AlkyBurninX's Avatar
Don't go over 352 if you want any reliability. I had a 352 kit at 13:1 compression and it would scream. It was on alky. I then built the 410x. I was looking at building a 350x based engine for my 250, but I finally realized that $2000 in it couldn't hold a light to $2000 in my banshee.
The Z's weren't out when my orginal 273 big bore was in the motor. It would run with stock 400ex's though. On alky, it would run with piped 400's. The 352 would definetly outrun cammed and piped 400ex's. The 410 will outrun 440's on gas, but I think if the 440 was also on alky it would get me. After seeing Pudjumpers 400ex run a couple of weeks ago, it would take one STOUT 350x motor to even think of running with it.
Old Mar 25, 2003 | 08:25 PM
dirtgirl's Avatar
Pro Fab ATV has a 385cc kit for the 300EX but for the 250X they have a 350cc kit... that's the biggest I know of for the 250X.
Old Mar 25, 2003 | 11:19 PM
Need4Speed's Avatar
330 kit does wonders when you have cam and all that other good stuff with it.
Old Mar 25, 2003 | 11:29 PM
dirtgirl's Avatar
YEAH!!!
Old Apr 7, 2003 | 07:31 AM
snowbuster's Avatar
380cc big bore kit. for that kind of money sell your 250x and buy a new quad with more ccs.
Old Apr 7, 2003 | 08:10 AM
hey snowbuster maybe you should be quiet, you don't even own a sport quad.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 7, 2003 | 11:23 PM
dirtgirl's Avatar
These are the kits from Pro Fab ATV
385cc kit for 300EX
350cc for 250X
All Bore kits - Provides Monstrous Torque
Kit Price $1295
Bore Kit $349
Kit includes:
Custom JE 86mm Piston/Bore Kit at 12.5:1 compression
Jagg Oil Cooler
All Honda Gaskets and Seals
Three Angle Valve Job with new Valve Seals
New Spark Plug and Oil Filter
Heavy-Duty Clutch Springs
CDI Rev Box Mod
Clean/re-jet Carb
Vent Airbox Lid, if needed
Includes all shop labor necessary to re-sleeve cylinder, machines cases, reassemble to race specs
Check and inspect transmission, clutch, perform trans shim mod for better engagement.
Note: Does not include camchain, clutches, transmission parts or valves.
__________________________________________________ __________________________________________________
"Budget Racer"
High Performance Engine Kits
330cc kit for 300EX (295cc kit for 250x)
$899.00*
Kit includes:
Our Custom 330cc Big-Bore Kit
Jagg Oil Cooler
All Gaskets
All Labor
All Machine Work
Overhaul Cylinder Head with three Angle Valve Job and new Valve Seals
C.D.I. Box REV Mod
Includes all disassembly/reassembly
Ship it to us and you get it back ready to Install !!!!
__________________________________________________ __________________________________________________ _
If you just want the bore kit here it is:
Engine Kits - High Performance Specials
385cc kit for 300EX (350cc kit for 250x)
$349.00*
Kit includes:
Custom JE Piston at 12.5:1 compression
Sleeve
Rings
Clips
Heavy-Duty Pin & Gaskets
*Note: This kit requires cylinder sleeving, race gas, an oil cooler & case machining for access to accept the humungous big-bore sleeve. Parts only kits and machine work and shop labor are extra.
Old Apr 7, 2003 | 11:32 PM
dirtgirl's Avatar
Hey need 4 speed:
are those 250R a-arms I see on the front of your quad? It sits low like mine so I was just wondering if that is what they were. Yeah you can build a potent little quad that works great by building a 300EX or a 250X the only thing is they like to rev fast and they sure could use a 6th gear...
