Carb problem?
Old Mar 25, 2003 | 10:21 PM
voodoo's Avatar
Default Carb problem?
Was out for a bit this evening and the bike just up and quit. Sometimes it just dies, like no fuel, or backfires a lot then dies. It eventually run again. Some times have to prime it??? Any opinions? The carb is right here on my desk. HEhhe
Old Mar 25, 2003 | 10:45 PM
Bigcat's Avatar
Hi, vewdew check your gas tank you have a screen type filter , it could be cloged. By the sounds of it , it starving for gas. Do you have a kink in the vent tube? Or is the needle or float stuck and won't let any gas in the carb. Well you got it off now you might as well clean it. And adjust your valves while the gas tank is off.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 25, 2003 | 10:54 PM
voodoo's Avatar
Wheres the screen filter? Is that in the petcock? Thx for the reply btw ;]
Old Mar 25, 2003 | 11:02 PM
Cat500i's Avatar
I read alot of reviews before buying the Cat500i 03'. I read that the connector on the coil was faulty on a lot of wheelers. There is a cheap liitle plastic connector on the side of the coil that alot of people said they had trouble with. I siliconed and recrimped mine when I bought it. Might be worth a check.
Right side in front of engine.
Old Mar 25, 2003 | 11:09 PM
voodoo's Avatar
Hmm come to think of it, it kinda acted this way when i had the wiring harness problem.
Old Mar 25, 2003 | 11:10 PM
Bigcat's Avatar
I got the service manual out and it doesn't list one. It should be in the gas tank where the fuel hose comes from the tank going towards the Gas tank valve. I hope this helps. By the way it says here to change your gas/vent hose every two years, you could have a cloged hose.
Old Mar 25, 2003 | 11:12 PM
voodoo's Avatar
Thx BC, i checked that stuff. Im going to go over this carb anyhow, good practice ;]
Old Mar 25, 2003 | 11:15 PM
Cat500i's Avatar
When it quits you can stop and pull the plug or just grab the plug wire. You can tell real quick if its gas or spark problem. Kinda hurts though.
Old Mar 25, 2003 | 11:23 PM
voodoo's Avatar
I think im with you, id bet its an electrical problem, heh. Carb looks real clean btw, no dirt visable in bowl at all. Looks can be deceaving but...
Old Mar 25, 2003 | 11:34 PM
voodoo's Avatar
I drew some arrows here, can someone tell me what each one is? carb
