Greasing the Raptor
Old Mar 27, 2003 | 04:57 PM
Ziggymon's Avatar
Default Greasing the Raptor
Help,
Do any of you have a problem greasing your raptor's bearings? I have a good quality grease gun and use lithium grease but for the life of me whenever I hook up to the zerk fitting and start to pump the grease pushes the nozzle off and grease just blows out around the fitting. The harder I press the nozzle on, the harder it is to pump the gun and it still won't go into the bearing???????????? Any ideas?
Old Mar 27, 2003 | 05:03 PM
Raptorx44's Avatar
Sounds like the zert is clogged, i clean mine with a needle or knife blade, zerts are cheap if they need to be replaced.
Old Mar 27, 2003 | 05:30 PM
RacinJason's Avatar
clogged fitting....go with something better than a lithium based grease...heavy dutiest nastiest stuff you can find....I use a chevron grease(purple).
Old Mar 27, 2003 | 05:55 PM
raptor03's Avatar
or you are full,but check for it being clogged..
Old Mar 28, 2003 | 12:39 PM
Ziggymon's Avatar
Many thanks guys. I appriciate the fast response.
Old Mar 28, 2003 | 03:26 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Yamaha grease jerks are about $3.00. There are not the same jerk as lets say your standard car jerk.
Be carefull when pulling the gun off because one of mine pulled right off when I pulled the gun off.
One of my upper a arms will not take grease either even with a new fitting. Its looks full of grease with the fitting off though.
Old Mar 28, 2003 | 04:40 PM
garyc660R's Avatar
If you jiggle the tires and there is slop, it jerk needs lubed. I can really feel when mine needs lubed. I recently got 344 more hours out of my porch light than advertised....pretty good huh?
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
bigred20653
Sep 19, 2015 02:11 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
