Doe's your V-Force make a noise when shifting
Old Mar 28, 2003 | 07:46 AM
NYds650's Avatar
Default Doe's your V-Force make a noise when shifting
My V-Force makes a chtk noise when I shift it from neutral into drive, or from neutral into reverse is that just the engagment or is there a problem. Thanx
Old Mar 28, 2003 | 09:54 AM
mtecate4g's Avatar
Thats normal. My P650 and 700's do the same thing. Its just the engagement. If it does it real bad you may have your idle set a little high.
Old Mar 28, 2003 | 10:18 AM
NYds650's Avatar
It's only a slight noise I was just making sure thanx for the quick response.
Old Mar 28, 2003 | 10:21 AM
DHP400ex's Avatar
Was wondering if you all have removed the linkage from your rear-foot brake to make it easier to engage in reverse? It makes it alot easier to do this way.
Old Mar 28, 2003 | 11:34 AM
mtecate4g's Avatar
I have been thinking about that too. Havent done it yet but i do get sick of having to use the brake to get into reverse all the time.
Old Mar 28, 2003 | 12:29 PM
DHP400ex's Avatar
Removing the cable and linkage only takes a few minutes and makes it alot easier to shift. You'll need a couple of washers to make up the difference when you take off the bracket that holds the linkage cable.... or the bolts will be to long. Later
Old Mar 28, 2003 | 02:11 PM
SpydrFreak's Avatar
Excellent idea! I'm gonna unhook that tonight.
greg74
Sep 10, 2019 03:03 PM
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
