gas keeps leaking.....help
Old Mar 28, 2003 | 04:00 PM
SCOOT400EX's Avatar
Default gas keeps leaking.....help
ok gas keeps coming out of the over flow tube. So I changed the float because I thought it was getting stuck.
Now the gas is still leaking after I put the new float on. What can this be? The bike is a mini tank Lakota.
Old Mar 28, 2003 | 06:44 PM
Hardwood's Avatar
When you take the float off you will see a valve or plundger that comes to a point up inside the carb and that is what stops the gas flow, and if it gets wore just a little it can make the bike lose gas through the over flow and make it spudder when going over bumps at speed. Check the point where it seals, if the point or tip has any wear on it, it is bad and must be replaced. The tip must be near perfect. I had this happen to me,and that was the problem.
Old Mar 30, 2003 | 09:43 AM
Hardwood's Avatar
The proper term for this is needle and seat.
Old Mar 31, 2003 | 03:32 PM
SCOOT400EX's Avatar
thanks hardwood but i just needed to adjust the float. when i ride i could be in 5th then all of a sudden it loses power
and all of a sudden it gains the power back. Do you know what this could be?
Old Mar 31, 2003 | 08:51 PM
Hardwood's Avatar
Well it could be a couple of different things, this to could be signs of a bad needle and seat also if it does this over bumbs at speed or it could be something as simple as the plug since it was running rich it might have weakened the plug. I would change it first to see if that takes care of your problem... Good Luck.
