squeaky raptor
Old Mar 28, 2003 | 04:45 PM
wildwildweb16's Avatar
Default squeaky raptor
Whenever I wash my raptor and it dries there is a terrible squeak that just wont go away. It continues to make the noise for a long time after. I have tried spraying wd-40 on just about everything and the squeak still doesn't go away. Does anyone have any ideas on what to do to get rid of it?
Old Mar 28, 2003 | 04:54 PM
BLASTERDEVIL2's Avatar
jump something big and hit flat. maybe it will knock it loose? jmo
Old Mar 28, 2003 | 05:21 PM
RacinJason's Avatar
grease? In the a-arms? and shock linkage?
Old Mar 28, 2003 | 05:25 PM
RSO660R's Avatar
Its probably the shock bushing squeaking on the shaft. Mine did the same use something other than wd-40 it will dry out the bushing. I used some silicone lube. never had a prob since.
Old Mar 28, 2003 | 07:37 PM
raptor03's Avatar
It's comong fro the rear shock huh? and if it is it's the top of the rear shock where you can adjust it,it's louder than hell,i just sprayed in there and it came out but i coldent find the squeek till i was so pist i wouldent give up..
Old Mar 28, 2003 | 11:09 PM
Raptordan's Avatar
The squeak is probably coming from your lower bushings on the front shocks. To solve the problem, take the bolts out where the shock mounts to the lower control arm. Tap the bushing out of the shock and clean all the rust and dirt off of it. Take some STP oil treatment, and coat the outside and inside of the bushing and the shaft of the bolt. Re-assemble and have a quiet ride. I did this about 3 months ago and I haven't heard a peep out of them.
Old Mar 28, 2003 | 11:45 PM
RaptorRacer1's Avatar
On my '02 the squeak was caused by the rubber bushings on the top rear shock mount,. where it attaches to the frame. As mentioned earlier, do not use WD-40. It will dry out the rubber. use a spray silicone lubricant. Spray it good, go riding, and when the lube works its way in, bye bye squeak!
RR1
Old Mar 29, 2003 | 10:53 PM
RaptorRidr660R's Avatar
I had the same problem, Mine was the top rear shock mount and the lower front shock mounts, I took the bushing apart, cleaned then and used water resistant grease on them and solved the issue! Good luck, I know I hated every squeak on mine.
Old Mar 29, 2003 | 10:59 PM
Starky's Avatar
Maybe you have some grit between your brake pad and rotor.
Old Apr 1, 2003 | 04:45 PM
cool74's Avatar
Lol this recently happened to me last week. I loosened the top bolt that holds the shock a little bit and it stopped. If it happens again I will just take it off and clean it and grease it back up.
