How do you split the engine bock...
Old Apr 1, 2003 | 04:25 PM
robj8hammer's Avatar
Default How do you split the engine bock...
....on a 88 suzuki lt 230quadsport?
Old Apr 1, 2003 | 08:35 PM
jt8hammer's Avatar
ttt
Old Apr 2, 2003 | 09:50 PM
jt8hammer's Avatar
ttt sorry about double posting, but me and my bro^ need to know how to do it
Old Apr 3, 2003 | 04:35 PM
LT250RSuperstar's Avatar
Do you mean the engine cases? yeah ok first of all DON'T pry with a flat blade or pry bar. second ........ I'll get back to ya.
Old Apr 6, 2003 | 12:33 PM
jt8hammer's Avatar
yes, i meant the cases...Please help!!
Thanks in advance,
Travis & Rob
Old Apr 6, 2003 | 12:59 PM
fourlix's Avatar
You need a puller. This is a flat bar of steel that goes accross the end of the crankshaft with a large bolt right on the end of the crank. Each end of the puller is bolted to the case. Once everything is tightened up you screw in the bolt on the end of the crank and the case is "pulled" outward on the crankshaft, splitting the cases. Make sure all the screws holding the cases together are out before you start, usually you need a flywheel puller also, as there are usually case screws behind the flywheel.
.....To put it back together you can use allthread rods and nuts at the mounting flanges, where the cases bolt to the frame, to squeeze it all back together.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
RedRancher
Aug 10, 2015 01:28 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
