Grease nipples???
Old Apr 1, 2003 | 11:11 PM
suds's Avatar
Default Grease nipples???
I was greasing my quad nipples today, and was wondering how much is enough. Should I continue to pump grease in until it come oozing out or is a couple of pumps from the grease gun enough. If anyone could explain the correct way to do this that would be greatly appreciated. And if there is any consequences to adding to much grease at once.
Old Apr 1, 2003 | 11:26 PM
hannahj's Avatar
well i always do it untill i hear a pop then thats enough its usually about 2 or 3 pumps if you do it on a regualar basis
Old Apr 2, 2003 | 06:25 PM
suds's Avatar
Anyone Else??
Old Apr 2, 2003 | 08:02 PM
ProXPredator's Avatar
Basically depends on how old the quad is, how good the bushings are, where you are greasing it and so on. On my 95, she's getting pretty old, so I put grease in until I see a little come out by the bushings, I know the bushings arn't the good anymore, so there is play in there where the grease can come out. On my Predator, I just use about one pump, unless it feel like it went in too easy, then a little more.
Old Apr 2, 2003 | 10:58 PM
Ronnnnn's Avatar
if you pump in until you see a little come out then you know that there is no water or anything but grease in there which is what you want.
Old Apr 3, 2003 | 12:22 AM
PRAIRIETWIN's Avatar
Raise the rear up in air and put grease in rear axle housing while quad is running in gear until the water drops come out and you see a little grease, let it run for a while.
This has worked for me since '95 and the bearings were still good after 4500 miles, with only grass and weed parts in the bearings. Cleaned them and put them back in.
Old Apr 3, 2003 | 12:24 AM
modquad's Avatar
That's the aviation way. Nipples!? Did someone say nipples!? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 3, 2003 | 01:35 AM
I just knew someone would have to say "did he say NIPPLES"?? lol
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Jul 28, 2015 01:58 PM
Sandman2.0
Jul 21, 2015 09:03 AM
