sprockets
Old Apr 4, 2003 | 11:52 AM
SuzukiQuadrunner160F's Avatar
Default sprockets
will a 13 tooth frount sprocket from a 97 425 magnum 4 x 4 fit on my 96 425 magnum 2x4. i orignally had a 12 tooth i want a higher gear though.
Old Apr 5, 2003 | 02:48 PM
Default sprockets
anyone??
Old Apr 5, 2003 | 02:52 PM
Default sprockets
ok, does anyone know how much of a gain i would get on top end if i raised the frount sprocket 1 tooth?
Old Apr 5, 2003 | 04:33 PM
fullthrottle's Avatar
Default sprockets
Trying to get a reply is like pulling teeth, no pun intended. I have a post about wheel offset that no one can seem to answer also. The only advise I can give on this matter is to call a polaris dealer. You can change # teeth, I dont know if you have to go up or down in order to gain top end.
Old Apr 5, 2003 | 04:38 PM
Default sprockets
ok thanks thats all i needed to know i got the rest of the info.
Old Apr 5, 2003 | 05:00 PM
Mike Chero's Avatar
Default sprockets
The 13 tooth should fit, but you'll need snap ring pliers to get the snap ring that holds it on off. Also you might have to lengthen the chain to accomodate the larger sprocket. You, of course, could go to a smaller back sprocket too. They make the back sprockets in 42, 38, 36, 34 and 30 tooth sizes (30 tooth is from the axle to axle sprockets on a 6x6, it should work fine)
Old Apr 5, 2003 | 05:08 PM
modquad's Avatar
Default sprockets
Fullthrottle I personally try to get to posts I know about, especially if I see no one has replied. If someone doesn't answer, it could be that nobody on here has tried what you're asking about....don't know. Quadrunner160, along with what Mike suggested, I thought the Hot Seat brochure had a gear compatability chart, but after looking, it doesn't. You could call them, or Hotseatperformance.com, also Sprocket Specialties is another great source. Lot's of helpful people, kinda a busy time of the year, we'll try to help. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 5, 2003 | 10:32 PM
Default sprockets
modquad, I know we have alot of people out their that are quite knowledgeable, I was just trying to help someone out . I just figured that someone could have answered with a quick yes or no reply. Some post get many hits It would be nice to see everyone get at least 2 or 3 hits. I was just aching on someone knowlegdeable like yourself to help. Like you have done" many" of times . Lets move to the next post. Thanks and good luck SuzukiQuadrunner160F . Maybe you can help me on my post Wheel offset (polaris)lol
Old Apr 5, 2003 | 11:07 PM
NCScrambler's Avatar
Default sprockets
Going up one on the front will raise your top-end alot. Going up one in front is about the same as going down 2-3 in the back. The front would be cheapest, but you may not like the bottom end performance. You may have enough chain adjustment not sure about that? Yes the c/s outer sprocket on any 95-98 Magnum 4x4 should fit. (according to Rocky Mountain ATV book anyway) It also says that a 95 scrambler 400 with the 11-38 set-up has 84 links instead of your 86, so you may have to cut chain after all. RM ATV also sells an 11 tooth sprocket for the 95-98 Magnum's, so it must be a popular change?? They also have 34,(38factory),40 and 42 size rear sprockets for your machine. Hope this helps.
Old Apr 6, 2003 | 02:57 PM
Default sprockets
thanks thats just what i wanted to know. i wanted to replace the frount because my chain is pretty loose right now and instead of buying a new one i culd just make the sprocket bigger. I didn't want to do the back because id rather not take some links out.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
