My letter to high lifter
This is what I wrote,and i will let you know the response
Charles
I understand that the sub assembly or ring gear assembly which houses all the key components that make up the Arctic Cats performance is sealed and access to the components are impossible. I do know that with precision cutting you are able to gain access to these components. I also understand that it would be extremely time consuming and costly to have these procedures done. What I don't understand is why Highlifter cannot obtain an after market or factory sub assembly like I have, and build an after market assembly based on the measurements and precision crafted parts to be capable with the others components that make up the entire 4x4 system. This in my opinion would only cost you the price of the factory sub assembly. The rest would be financed by your department of New developments. I strongly believe that with a little effort and combining the intelligent brains that work for Highlifter this could be done.
As far as cost and demand why not make it a pay in advance type of transaction to pay for this new system until the market gets off the ground. I assure you-you would not be able stock the system from all the Cat owners swiping them up as fast as you can make produce them.
Thank You for your time
Scebo King
Charles
Scebo King
