My letter to high lifter
Old Apr 4, 2003 | 01:22 PM
CatKrazy's Avatar
Default My letter to high lifter
This is what I wrote,and i will let you know the response
Charles
I understand that the sub assembly or ring gear assembly which houses all the key components that make up the Arctic Cats performance is sealed and access to the components are impossible. I do know that with precision cutting you are able to gain access to these components. I also understand that it would be extremely time consuming and costly to have these procedures done. What I don't understand is why Highlifter cannot obtain an after market or factory sub assembly like I have, and build an after market assembly based on the measurements and precision crafted parts to be capable with the others components that make up the entire 4x4 system. This in my opinion would only cost you the price of the factory sub assembly. The rest would be financed by your department of New developments. I strongly believe that with a little effort and combining the intelligent brains that work for Highlifter this could be done.
As far as cost and demand why not make it a pay in advance type of transaction to pay for this new system until the market gets off the ground. I assure you-you would not be able stock the system from all the Cat owners swiping them up as fast as you can make produce them.
Thank You for your time
Scebo King
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
