Shaking 300ex
Old Apr 24, 2000 | 10:43 PM
hondatrx300ex's Avatar
My 300ex will run about 55 and when I get up to about 45 my bars start shaking. what could this be?
Old Apr 24, 2000 | 11:41 PM
THEXOTIC1's Avatar
the steering stem bottom bearing could be bad also check the front end for an alinement bent tire rods bent rim etc...
Old Apr 25, 2000 | 03:11 AM
hot_shoe_cv's Avatar
Assuming none of the above-mentioned mechanical difficulties are present you may simply have a case of head shake which can be caused by certain aggressive tire tread patterns. In my case it was solved by the addition of a damper which was a big help in other ways also
Old Apr 25, 2000 | 09:24 AM
well it may just be a little head shake.
Old Apr 25, 2000 | 10:23 AM
fasttrax's Avatar
Check your rear axel. You could have a out of balance tire too. On vehicles you pick up a vibration at higher speeds and if not corrected soon you could have eggs for tires.
Old Apr 25, 2000 | 11:01 AM
JAKOOL's Avatar
Unbalanced front tires.
Old Apr 25, 2000 | 04:50 PM
I think it may be unbalanced front tires. cause one is a litte more wore than the other.what is the easiest way to fix this?
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
toonces
Sep 5, 2015 01:14 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
